Radius Arm upgrade
Bitch'nBronco
Loose Cannon
Ringwood, NJ
Noticed my poly C bushing is cracked yesterday and figured if I'm going to go through the trouble of replacing the bushings I might as well upgrade my radius arms. I'm torn between the Duff T Rex arms and the All 4 Fun long arms (mostly because of price). I'm not really looking at them for maximum flex since I only do light wheeling and mostly want the upgrade to correct my caster angle. I have a 3.5" lift and would like recommendations one way or the other. Thanks
https://all4funoffroad.com/Long-Travel-Extended-Radius-Arms_p_57.html
broncobuddha
I get it, JD is typically way more expensive on most things.
If the A4F arms were say $500 Id say do that. Given they're only $100-$200 cheaper then what you'd end up paying for Duff's T-Rex or extended arms, I say go with Duff's.
Sent from my Pixel 6 Pro using Tapatalk
