Radius Army Bushings
Rocko1012
Replacing just the Radius arm bushings. Purchased new from vendor,
Bushings do not have any offset at all. Is that correct. It appears both sides are exactly the same
gr8scott
Correct, both the same. Hope you got the rubber ones.
R
Rocko1012
Yes, I got the rubber. Now I have to go try to reinstall. Thanks for response
mrdrnac
Wildhorses used to offer a Rubber set that was offset (Their number 1390); however, I don't see it on their web site now? They do show a picture of them when you look up "Bushings"
I thought it was BC that was having the offset rubbers made. 10° angle molded in. Takes out a lot of the rubber bind on trucks with taller lifts.
Don't worry, the normal rubber bushings will take a set to the new angle in short time.
use a large ratchet strap or come along to pull the axle back in place to get the hardware on. especially the C-bushings.
