raduis arm broken need info
Where can i find a new one of theses which website has deals with springs and all supension
needabronco
Prescott/Farmington
Where are you located? Your best bet is find one for sale here or call Randy at Driven (advertised above). A local sale would be your best bet... I'd also replace them as a pair for obvious rust reasons.
trailbound
all of the sites are about the same in pricing.
bc
wildhorses
broncograveyard
Toms
Problem you have, if its not just the bushing and truly is the stud. You need a whole new radius arm. I think only broncograveyard sells original used arms. Your best bet is to link up with a local club and see if anyone has switched to long arms and wants to sell/give you their old arms.
needabronco
Prescott/Farmington
Wild Horses would or Tom's would likely sell you a set of arms also. Again your location would help determine your best coarse of action. Shipping on a pair of arms is spendy...
I have one sitting in the garage that makes for a great door stop (don't have to bend over to pick it up).
Like they mentioned, shipping will the the bigger bullet to bite.
Be aware there are 2 different arms. The '66-77 Bronco has a different bolt spacing for the spring plate then the '78-'79 Bronco. Not sure how the truck versions fall into this? Really not that big of a deal, worst case is drill a new hole or two for the spring plate. That's it.
If that arm died, figure the other isn't far behind. Be looking for a pair.
Buldozer
Bronco Virtuoso
God's Country
Your location would be helpful as others have said....assuming you have an early bronco, a lot of folks on here have stock arms laying in their bone pile most likely but without your location your not going to get the most helpful responses here.;)
Apogee
No offense, but did this really need a new thread? You have almost an identical thread that you didn't really respond to here where it was also reccomended that you post up your location since a lot of guys have these things laying around acting as glorified paper weight/door stops/etc. I've got two sets myself, one from my EB and another from a 76 F150.
Location, location, location. Help us help you out.
