Ram Assist Questions
SurfCityEB66
I'm in need of rebuilding my power steering system and thought of upgrading to the ram assist. I've searched threads and found most of the information I've been looking for, would be great to hear feedback:
My Bronco - 5.5 lift, 37's, has PS now, D44 w/ x-over stone crusher kit. I do 90% offroad and flat-tow to trails.
Problem - Steering is sloppy with dead spots, pump squeals, gearbox leaks.
After researching here I called Lee Manf. and this is what they suggest:
$560 to rebuild gearbox, add fittings for ram assist, ram and tie-rod ends
$$? - for lines and either rebuild or replace pump
Seems reasonable to me but if I've learned anything this far it's to do it right the first time. Compared to PSC its about half the cost, am I missing something important here?
My other questions are:
1. What affect does the ram assist have on flat towing?
2. What pump would work with this set-up now and a future Hydro Brake Assist (astro) set-up?
3. What is the steering ratio on the stock PS gearbox?
4. What stroke would I need on the ram....8"?
5. Does the steering w/ ram assist change anything at freeway speeds?
Thanks,
Brian
bronconut73
Lots of good questions. I'll be watching this thread. The Ford vans often had a saginaw pump with two returns for the hydro boost. Lincolns too. Before learning this on here I bought a saginaw pump for a 73 chevy 1 ton truck, but it's only single return. It is working fine though but probably not what you're looking for.
I look forward to what you learn about ram assist.
Nightstick
Bronco guy
PSC ported and rebuilt my 4x4x2 box. I used their products for eveything (ram, port job, lines, heim joint TRO kit), and a dual return saggy from scrapman. I also ran astroboost brakes. My whole setup including the TRO stuff from PSC came in around $1100, with the TRO stuff being probably half the cost, so I don't know how they quoted you that much for just a port job and ram. Are you pricing heim joint ends with it or something?
It's night and day difference from just having power steering. I didn't notice any difference on the highway, yes on the 8" ram.
MarkH@Wildhorse
Stockton, CA
You will want a Heavy Duty dual return Power steering pump for sure if you're going to go to hydroboost later.
The reason our kit looks the most expensive is it's a complete kit, including a new box and all the lines.
If you need it broken down, we do that too.
Ram - $195
http://www.wildhorses4x4.com/product/Extreme_Steering_Ram
Hose kit - $75
http://www.wildhorses4x4.com/product/Ram_Hose_Kit
Dual return reservoir and pump $429 , http://www.wildhorses4x4.com/product/HI_volume_pump_w_pulley
Then you are just sending out your current box for a rebuild and a porting job.
If you feel creative, you can port your box yourself as well.
Nightstick
Bronco guy
I would suggest getting a 4x4x2 box instead of using the stock one as well.
Kyle.malone
Norman, OK
you can run a single return pump. you dont need a dual return. Put a T in the return line. The only time the hydroboost puts fluid into the return is after you push on the brakes. If you are looking into hydroboost as well, look at Vanco for a unit. Or just purchase a Junkyard one and send it to them to be rebuilt and Highflowed. Some hydroboost units when running a ram have no problems but some need to be highflowed to allow the adequate pressure for the steering gear box and ram. Before I went to Hydroboost, I went through two junkyard units and both were not working (had manula brakes only) I ordered the WH unit because it was turned at a 90 degree angle and cleared my tall valve covers. I ran it at OCBR and couldn't turn in the rocks but i had awesome brakes. I am waiting on getting my unit back from them now, but they can make it where the brakes work correctly and machine it to allow pressure to still flow to keep the gear box and ram woring correctly when on the brakes. Vanco will machine and rebuild for $350.
But like I said earlier some need theirs highflowed and some don't. I was just one of the lucky ones that needed to be done.
bknbronco
North Metro, MN
My dad just added ram assist to his jeep and its quite nice so far. I hear over and over to use a 8" ram, but if you mark and measure the tie rod from full right turn to full left turn, you may find 8" ram to be way too long. My dad got like a 6.5" ram and its perfect for his jeep. I have yet to measure my tie rod travel from lock to lock but im pretty sure 8" may be too much. If the ram pushes more than the tie rod travel it could tear mounting tabs and such off. I have heard of guys putting washers inside the ram but why not just get the right length ram??
I also suggest the 4x4x2 box. I found two old 4x4 boxes for dirt cheep ($20-$50) the newer style boxes are dime a dozen. The internals swap can be done yourself as can the porting. Scrapman has both the 4x4x2 boxes as well as dual return pumps. The dual return pumps can also be bought at local parts stores. I suggest a cooler now because of the added loads from hydro and the ram. Hoses can be made yourself with aeroquip hose and compression fittings.
SurfCityEB66
SurfCityEB66
Ram - $195
Hose kit - $75
Thanks for the info....I may just end up calling you guys to piece the rest of it together. PSC said I need their gearbox ($975) or the retro kit $1500. I would like to keep it around a grand if possible.
PS I'm flattered you wanted to follow me on Instagram LOL (schiada_boy)
Thanks for your input! I should actually take a better look at what I have, my bronco is stored 50 miles from me but I'll be up there this weekend. The PO pieced everything together so I'm not sure exactly what I have, I know the column is out of a 77, and I know the lines come off the top of the gearbox...looks like I have more homework before I spend my kids diaper money!
blwngsket
Novato
I used the Wild Horses Kit for the ram assist, the power steering and the hydro boost brakes. My truck has an 89 5.0 rolling on 39.5 Pitbulls on H1 dbl beadlocks (About 150-200 lbs per corner). Some say it may be a bit on the spendy side but it's your steering and brakes! It's kinda important. just sayin.
That being said. It's a no brainer, complete and easy kit. You can install it in a day ( I did, but who am I?) or a weekend, and it's bad ass. I can one finger steer on the Rubicon with 2 PSI in the tires with no squeal or strain of the system. Very well engineered (SP?). PSC Parts I believe. And the brakes? With 4 wheel disc brakes the hydro assit will put you into the windshield without your seat belt on.
Good luck.
T
MarkH@Wildhorse
Stockton, CA
With Instagram, it's hard not to stalk/follow. I love Surfing and EB's. I was actually at the bluffs for the Mavericks the other weekend, well, until I was kicked out and had to go watch the rest of it at the "event" on the TV.
