Ram assist questions
M
moeszyslak
I put a framing square on the axle to the tie rod made marks on both. Cycle left and right made marks on both then measure it. Limit thay measurement by 1/8
This is what I did to measure. I need to reconnect my steering box to verify. Im trying to modify my pitman arm so it doesn't have to be keyed to the box. I would like it it point straight back with the wheels straight and it currently won't.
M
moeszyslak
I think I got lucky on my combination of parts.
Big bronco 4*4*2 box
F150 knuckles
Custom built drag link and tie rod
I have stop to stop range on steering box which is 7 3/4-7/8
Axle stops, not in the box
My ram only has about 7 5/8-3/4 travel.
I should be good since the ram will be the shorter range of movement.
M
moeszyslak
Same here. I had to limit my PSC about an inch. Had an aluminum spacer made for it.
Turns out I need to limit my ram about the same amount. I need to limit travel both directions. Do I need two spacers? I'm assuming two, one on each side of ram piston. I've never had one apart so I'm not sure. Thanms
M
moeszyslak
Kinda what i was wondering. I need to move the mount closer so it will bottom out while the ram is all the way in. And ass limiting spacer to limit the ram from extending to far. Am i correct on my thinking?
