tutone
- Oct 21, 2014
- 20
I had a shifting issue w/ my RAN transmission so decided to pull it and rebuild. After rebuilding and installing it is tight in reverse. All other gears seem fine, but reverse is very tight all the way from neutral to full engagement, and tight to shift it back out.
When I loosen (a full turn) the 5 bolts between the transmission and xfer case adapter, the tightness goes away and it shifts fine. All linkages are fine and not binding or interfering and the issue exists even without the shifter linkages connected.
It's almost like the gasket between the transmission and adapter needs to be thicker, but I can't figure out what is causing the tightness when they are bolted together fully.
