Random carb stumble
Gas Pig
I’m proving out my truck. It’s stock ‘66 with rebuilt motor and carb. So the first 60 miles truck ran perfectly but on my way to the gas station I think I ran out of gas. I was suspicious that my aftermarket sending unit was showing more then what was in there. Anyways I put in 3-4 gallons she fired up run coughed and choked for a few moments then it cleared up. I drove up to the station topped it off. It seemed to be running back to perfect. About couple miles later went around a turn then it stumbled hard but keep running. At that point I headed home and it ran perfectly again!
Any thoughts?
ugly74
Bronco abuser
Colorado
Might wanna check your float levels, and change your fuel filter if you haven’t already.
spap
Was the tank ever flushed, you might have sucked up 54 years of crud and x2 of the filters and floats
Gas Pig
Gas Pig
Yes the tank was flushed and both filters are new.
The stock filter on the Autolite 1100 honestly is kind of worthless. I just remembered I think last build I bought a NAPA premium gold inline filter that was more then a screen stuff in the filter body.
73bronco302
Are the fuel pump and lines good?
Last year my 76 corvette stingray sbc 350 was acting up on me. Father was a mecanhic with own shop for 40 plus years. He had an electric inline fuel pump mounted to the frame under the passanger seat area about halfway between the tank and the carb. The pump did not look like it would normally be mounted there. But if it was good for him, then it was always the best way to go. So I replaced the same pump at the same spot when it would not start-run well. Bingo. Problem fixed. Ran like a charm.
The owner of my 73 had an electric Carter pump mounted on the left side frame about 3 to 5 feet or so north of the gas tank, with the small plate blocking where the stock pump is on the 302 block. I am putting in the exact same pump and all the lines will be new. The seller was also a mechanic.
AC932
x2 on checking float levels. Also should check pump for pressure/capacity. Is this happening at a certain speed?
Are you running points? Recently had a condenser with bad spot welds between the bracket that holds it to the distributor and the body of the condenser, causing it to lose ground occasionally. Car would randomly stumble hard.
Rustytruck
follow the gas hoses from the tank to the carb make sure they are not failing and hose clamps are there and tight. Any cracks or loose clamps hoses between the fuel pump and the tank can suck air and cause issues. after the fuel pump hoses are under pressure so leaks are obvious.
Gas Pig
Gas Pig
Ok I took the carb off and swapped it with another rebuilt carb I had on the shelf. The carb 2 ran fine for few minutes and started acting like first carb 1. So for curious sake I took carb 1 and installed it on my 68k survivor ‘66 U13 and I ran perfectly! So it doesn’t appear to be the carb itself.
So I’ll double check the fuel line and points and condenser.
What else should I double check???
Rustytruck
try running with the gas cap off in case there is a venting issue.
Gas Pig
Gas Pig
After changing cap, rotor, coil, even the wire that feeds the distributor it came down to the new $8 condenser. Went bad after only 60 or so miles. :mad:
I didn’t have another new one so pulled an old one out of a truck that last ran year and 1/2 ago. With old condenser it fired right up ran perfectly. Then I took it for test drive, 40+ miles later without a hiccup! ;)
Boy... I just love the crap made in Mexico and China. %)
Thanks to all for your help and input!!!!
