RCV Axles
jvself
I would like to upgrade my Dana 44 axles to RCV axles. If you have done this how difficult was it? Can the installation of the RCV axles be done without removing the steering knuckle? Is the center opening in the steering knuckle large enough to accommodate the RCV axles? I have 33" tires. I will keep the 33" tires but would like to install an air locker in the Dana 44
sykanr0ng
Do you have Ford disc brakes?
Or drum brakes / Chevy disc brake conversion?
The hole in the Ford disc knuckles is big enough that you don't need to remove the knuckle only the spindle, the drum knuckle hole is smaller.
J
jvself
If the RCV won't work without changing to the Ford disc brake setup what would be the best/strongest axle for an air locker?
J
jvself
Thank you for the input. Sounds like it will be the Wildhorses axles.
Thanks for the good words guys. To be clear though, you'll need to remove the knuckles for either style.
Because the Wild Horses axles utilize the larger u-joints, they don't fit through the smaller drum brake hole. Or if they do, it must be a struggle!
Either one is a nice upgrade, but either one requires that little bit of extra work. I would not let it be a deal-breaker though, if you're wanting stronger axles.
Do you need the strength of the RCV's? They are stronger, but most people are satisfied with the standard chrome-moly upgrades.
The biggest benefit of the RCV's though is their strength while turning. You may already know that and it might be why you were going with the RCV. But the chrome moly's will live up to what most of us put our Broncos to.
Good luck. Happy wheelin' too!
sykanr0ng
The RCV axles will work, you just need to take the knuckles off to put them in.
I have never heard of the Wild Horses axles being stronger or more durable than RCV but rather the opposite.
J
jvself
Thank you for the input. I guess I need to decide if the RCV axles are worth the extra 900 plus dollars.
bronconut73
Goodness no.
WH chromoly axles are not as strong as RCV's. They can't be. There is a huge difference in the way a CV axle takes on loads verses a conventional u-joint axle.
But the WH axle kit with the solid Yukon gold joints is the best bang for the buck.
Those u-joints are stronger than the axle and the axle is a lot stronger than a "new" stock axle much less an old axle with many miles on them.
Next step would be ctm joints then RCV's.
But again, bang for buck is uber strong with the WH axle kit. Most of us will never need the strength of the RCV's.
By the way my Yukon gold joints were installed on the axles and they fit through the drum knuckle hole. Tight but it fits. It helps to leave the zerks off until you have the u-joints past the knuckle.
Buying my wild horses axle kit was one of my better decisions for my EB
Thanks for the extra info bronconut. I had always thought it was a tight-ish fit in the large disc knuckle and near impossible in the drum knuckle. Good to know it still fits. Leaving the zerks off until done is small potatoes in the scheme of things.
The RCV's have both reports regarding the larger disc spindle hole. Some say they've installed them with the knuckles in place, while most I believe, say that to clear the the red poly boots, they had to remove the knuckles.
Glad you're happy with your axles!
Doyle
RCVs with boots on will clear the 78,79 knuckles. That's the only ones I have personal experience with.
nvrstuk
PNW
Just remember if you wheel your Bronco you WILL blow ujoints or axles...even CTM's/Yukon gold whatever... when you do you will be removing the knuckle on the trail to pull the grenaded parts out of the small Chebby knuckle opening...
If you can justify the cost go RCV...you will break the knuckles/ball joints before you break them.
If not, like mentioned several times the best axle/best ujoint combo while carrying spares for both sides is the way to go... just take enough tools to remove the knuckle so you can drive off the trail.
You might not wheel hard core so just go with WH best upgrade below the RCV's... stuff breaks. Grease them EVERYTIME you go wheeling...everytime.
You don't need to be wheel hopping and bouncing 40" tires on rocks to have stuff break, ask me how I know...
sykanr0ng
Since those use the same spindles as the other Ford Dana 44 disc brake set-ups but not the same knuckles there may be a difference in the hole size.
Probably fixable with a little time using a die grinder when installing the RCV axles.
marjama
I haven't heard of the need to rebuild RCV's all the time - if that was necessary, you'd think there would be a lot more complaints! RCV's use a big CV joint (same thing that is in just about every car on the road today) rather than a u-joint. All of them do well with frequent greasing.
One advantage not mentioned is that RCV's have a greater tolerance for power applied when turned to full lock. This may or man not be an advantage for you, depending on how you use the truck.
I was planning on going with standard axles + strong u-joints. However, when I calculated the cost of axles + high end u-joints, the cost was pretty comparable to the RCV's...minus a lifetime warranty and other advantages.
bknbronco
North Metro, MN
Thats why all the Heepers dont all have them in there mall crawlers. Because heeps dont have lockouts and the constant turning on the RCV's makes them wear out fast without rebuilding. On a bronco it wouldnt be a issue for most.
You guys must beat the piss out of your broncos.....i been on a few trails and never seen anybody ever break a axle of a ujoint. I seen stock spider gears break before stock shafts or ujoints. But for the cost some chromoly shafts and spicer joints are a great choice. I think the RCV fad fadded 2 years ago.
