- Joined
- Feb 6, 2010
- Messages
- 577
RE: Lower Track Bar Bolt Angle Question
I am shortening a 1977 F150 Dana 44 HP axle to use in my Bronco. I am cutting and turning the C's to get good castor angles and driveshaft angles.In mocking-up the Axle I have noticed that my lower track bar bolt will now be at about a 10 degree angle downward instead of parallel with the ground. I have an adjustable track bar I'll be using so I can get it installed OK; however, I am concerned if the angle of the lower mount bolt will cause a binding of the track bar movement during suspension travel up and down? If it will then I may have to cut and turn the wedges on the driver side as well as the passenger side? Suggestions? Thanks.
