What they said vtboy. And a VERY good call on your part to think about replacing old bearings. They may have been replaced at some point already, but unless you know for sure when that was, it's better to replace now than to go chasing your wheel down the highway some lonely night!
Look for a part number on the existing bearing, or at lest get a measurement to determine if it's a "small" or "large" bearing. About 2.8" is small, and about 3.1" is large.
Your seal and bearing will both be the same type.
Do not try to upgrade to the tapered bearing, as that requires a different size axle shaft.
Yours initially looks to be the small bearing type, but I haven't looked at the chart to see what the shape of the housing end indicates.
Some good news (compared to most old axle shafts) is that your seal area looks to be in great shape. A little cleaning with some 400 sandpaper (a few twists, with a little oil on them, then a cleaning) will make them like new again. Or at least the one in the pic.
Many have grooves worn into them, and rust pitting the surface. Not good for a new seal.
Appears that the PO's kept the oil level up to snuff and the oil condition clean.
