I would give this job a 1
if the brake drum comes right off and you don't need a slide hammer. I would give it a 2
if the brake drum comes right off but you have to use a slide hammer. A 3
would be in order if you have to adjust the brake shoes to get the brake drum off and use a slide hammer. A 4-5 ??? if after adjusting the brake shoes the drum still doesn’t come off and you start smacking the axle with a hammer to try and loosen up the drum and it pops off fairly quick. OK this is fun. How about a 10
if you just can't seem to get the drum off so you pick up a big sledge hammer, beat the living snot out of the thing, you finally brake the drum then you find the axle is totally screwed up so you order a complete new rear end from Currie a month or two later your job is finally finished.
The names have been left out to protect the innocent. Good luck! May the force be with you.
