Rear Bumper Lights?
JohnJohn
Richmond
I have seen a few Broncos with rear bumper lights so you can see when you back up in the woods at night. Or to piss off the guy tailgating you.
Anyone have a light recommendation?
I would like something about 2 or 3 inches wide by 1 or 2 inches high.
nik
Corcoran, CA
I got some exactly the size you're describing. Think I got em from Pep Boys or Napa...any local parts store like that should have them for about $20 or so. I wired them into my reverse lights and the light up real nice at night and I haven't had any problems with them for the 4 years I've had them. (except I crushed one with my Hi-Lift cuz I was up to the bumper in mud%)
Nik
Sbolt19
Colorado Springs
I saw some lights that were at Wally-world the other day that were about $20 and they would almost fit in the grill slats. You might go check to see if your local one might have something like that. The were fairly small and sounds like something you are looking for. Might even be the same ones nik is talking about.
tasker
all knowing of nothing
NH
rubber mounted tractor lights work well, have them hooked to a floor dimmer....use when needed! ;)
msweb
Stick with the $20 light sets that are being mentioned and you'll be just fine. I've got 3 sets on the shelf ready to go on the Bronco as soon as I wire everything up (each fender well for rock lights and a set for the rear). I also have a set on my F150 and love them.
Like Nik, I wired mine into my reverse lights and I also have a dedicated switch for them. You'd be amazed how handy it can be to have a work light or just something to illuminate the area when loading or unloading, fishing, etc.
Go to Advance Auto and you could even find some that are tinted blue (Pilot brand) to match your Bronco. Stay away from the LED "driving lights", IMHO they aren't bright enough for a night light. Fog lights vs. Driving lights are better since they're designed to disperse the light as opposed to a beam.
Good luck and post pics!
bronco loco
It never ends
Long Island New York
While we are on the subject of reverse lights. Anyone knows where can I find a reverse light similar to a hitch cover, to go into my 2" hitch receiver?, thanks in advance
G's Baja Bronco
Sunny SO CAL
I have a single hella 500 fog light with the HID conversion from My Ramcharger I plan to mount on the rear bumper. It was too much light, I might go with 2 LED fog light from walmart, thin and low power consumption, about 25 dlls.:cool:
piack
Sanford, Maine
I'm looking for a set of bright LEDs in a 6-8 inch strip. I've seen some cheapo's and seen some $200-'s. Anyone try them yet for back-up lights?
JIMS74
PORTSMOUTH, VA.
I am using some lights off a fork truck, that I don't remember how I ended up with them.
