Rear Carpet Hold down( HELP)
Flash69
Southwest Va
Does anyone have a pic of how the rear carpet hold downs go. Mine dont look right. Id really appreciate a pic. Thanks.
dustybronco
no pic but...
the rear hold down has the flared up side toward the back and is suppose to have a small rubber seal btwn it and the tailgate. just pulled one off yesterday and thats how it was installed from the factory.
69marquisragtop
Roanoke, VA
Flash, the '76 I bought a couple of weeks ago doesn't have carpet, but the rubber mat instead and it is held in place with the trim strip dustybronco mentioned. I will get a pic for you this evening if it will help.
SeaBiscuit68
Tacoma Wa
I have this picture but it probably doesn't help you. It sort of implies that carpet went on the tailgate too, hmmm. I wouldn't know though as mine doesn't have carpet.
MnkyBiz
Northern VA/DC
Flash!
Go half way down on this thread and you will see a black steel strip running along the rear of my bed. This is the piece that holds down both the tailgate weather seal & the carpeting.
HOpe that this helps.
MnkyBiz
Flash69
Flash69
Southwest Va
Thanks Seabiscuit Thats exactly what i needed. Thanks to all the other guys also. I sure didnt know the gasket strip in the rear held it down i thought that one of the new pieces that came with the kit held it down. I have been scratching my head wondering how both of those pieces went in the rear.
mitzel
Googleplex
Flash69
on the two I have the strip MnkyBiz is talking about is only for the
weatherstrip. mine have a separate carpet holddown similar to the
piece that runs between the front and rear carpet sections. maybe pieces
we're different for various years, mine are '76. if I get a chance I can
maybe take a picture of mine tonight and post tonight or tomorrow.
danny
mitzel
Googleplex
I found this picture I'd posted in another thread a couple months back
when I was trial fitting my carpeting and interior pieces. you can
sorta see the silvery piece is the carpet holddown and the black piece a
little more to the rear is the weatherstrip holddown. anyways that's how
it all fits together on my '76.
Flash69
Flash69
Southwest Va
Thanks mitzel.. Im wanting me some inserts like you have in the pic too. Ive been planning on making me some. Im not sure what to make them with yet. I have my upholstry material that i want to put on them im just not sure about using plywood.. Any opinions.
mitzel
Googleplex
Flash69
mine are made out of plywood. two 1" thick pieces screwed together. that
gives enough room to router out a 1" recess on the front side to flush mount
some speakers. then most of the backside interior has been routered out
just for some weight savings. I've attached below my picture of the back
side from an earlier thread posting. I don't have any picture of the front
side with the covering off. my covering is just some foam backed headliner
material. very easy to mount using spray contact cement and then 1/4"
staples all along the back side to anchor it.
one issue with inserts as thick as mine is you won't find an off-the-shelf
roll cage to fit in the rear as they normally mount very close to the bed side.
you could probably fit some 1/8" or 1/4" plywood inserts with many
aftermarket cages, that would be fairly solid and allow mounting 6x9 or
smaller speakers.
Flash69
Flash69
Southwest Va
I bet you have some good sound with those speakers. I didnt even know the big ones was in there. That a good setup.
69marquisragtop
Roanoke, VA
Flash, looks like you found what you needed. As promised, here's a pic of mine in case you still need it.
MnkyBiz
Northern VA/DC
Mitzel,
What are you running in that panel? Two 8"ers and a 6.5? Do you have that same config in each panel?
Thansk
MnkyBiz
Flash69
Flash69
Southwest Va
Thanks 69marquis The pics clears it up. I was looking at doing mine that way i just wasnt sure. I put a new metal bed in mine so im going to have a lot of holes to drill. That sucks. Thanks for all the replys Guys.
mitzel
Googleplex
MnkyBiz
> Mitzel,
each bedside has low pass to two nakamishi 8" subs and then high pass
goes to a JL audio 4.5" two way. I've got high pass wired to the front
too. once I get my cage back in I'll be hooking those up to a pair of 4.5"
two ways mounted to the cage or maybe some type of wiper cover +
speaker enclosure. the subs have a greater mounting depth than a
typical 6x9" or smaller speakers, which is another reason why my inserts
are so thick. this provide extra room so the back side doesn't hit the
bedside sheetmetal. I've mostly re-used stuff I had laying around so it's not exactly
tuned for maximum audio performance but I figured with enough drivers it
should be able to overcome roadnoise even with the top and doors off. :)
plus it's fairly space efficient, stealthy, and once I get my cage back in
it'll be theft proof (unless someone pulls the 8-point full family cage).
