jboomer
I went ahead and attempted adding a drain to my 9" rear today and it didn't go so great. First hole I drilled missed the internal compartment completely. Re-drilled next to it and a little higher and hit the compartment, however the case is only about an 1/8" thick. I bought a 1/8" 27 NPT tap and a brass plug, however that fine of a pitch just pulled right through and screwed up the hole. I was able to tap it with a 3/8" 16 though and bought another plug for it. Now, even with pipe tape on the plug, it's still leaking. The plug seats really tight, it just won't quit leaking though.
I was under the impression from another thread on this that I could do it without pulling the rear end completely out. What are my options to fix this? I don't know if RTV will stick to it or not...or if that's even an option. Am I going to have to weld it shut? I don't want to go to a bigger plug, because then the pitch just gets bigger which would make it worse.
Here's one of the few threads I referenced for doing this:
http://classicbroncos.com/forums/showthread.php?t=115941&highlight=rear+drain
