RnrdTheFox
** SOLD ** Rear disk for small bearing 9 inch
Up for sale is a set of rear disk brakes that came off an early 90s Crown Vic that I've been running on my small bearing 9" for about three years. These are similar to the Explorer style that fits the Torino housing ends. I liked these because they allowed me to keep the parking brake. Everything in the pic is included:
(2) rotors redrilled for 5 x 5.5
(2) backing plates with parking brakes
(2) calipers and brake hoses
(2) parking brake cables that with the correct end to attach to the backing plates. They will fit the universal parking brake sleeves sold by the bronco vendors. Mine are from James Duff.
A couple things to note about this setup. To set these up correctly, you should put a spacer between the bearing retainer plate and the bearing that makes up for the additional space of the thicker backing plate (~ 3/16). I believe these brakes are meant to be used with a brake off-set of 2.5" where as the small bearing has an off-set of 2.6". Also, my axle seals were leaking and although I've taken the time to clean these up, you would need to spray them down well with a can of brake cleaner on final assembly. Finally I had to trim the bottom of my axel flange just slightly to get the backing plates to sit flush.
thanks,
Renard
thanks,
Renard
