rear disk wheel stud???
broncodan1
Hey,
Hope someone can tell me what studs to buy, I've got
Chucks rear disk brake kit, did an axle upgrade and need to replace the studs.....You just can't walk into an auto parts store and ask for one of these.......lol
thanks,
Dan
honkey84
ILL
Before you go out and buy the studs what kit did you get??? I bought just the bracket kit and got the studs with mine. Maybe chuck forgot to give you a set??? I have the part number for the studs also though. Bendix part number 142199. You should have an instruction sheet that tells you all the parts numbers.
B
broncodan1
Hey,
Thanks for the part number! I bought Chucks complete
kit, but that was 2-3 years ago, and I know I've got the
paperwork somewhere......packed away, like most of my stuff, moved 3 times since I did the brakes, recently upgraded the axles, and the guy used the old studs in the new axles and they're loose...I'll try that part # tomorrow!
Thanks again,
Dan
honkey84
ILL
Dan whe you look at the new studs they should have about 3/8-1/2 of material that is pressed into the rotor and then about 3/4" that is threaded for the lugs. Hope that helps.
