Rear driver side wheel leaking oil
TarheelEB
1977, 302, C4, Rear Drums, Front Disks. The driver side rear wheel is leaking fluid. I think it is gear oil. I read through previous posts with this issue and found that it may be a seal leak that is leaking gear oil. Should I replace the seal and bearings? I found the seal for $12 and the bearings for $21 at a local auto parts store.
bknbronco
North Metro, MN
Mine leaks there also. Id replace the seal, but no since replacing the bearing unless it feels rough when you spin it. Just make sure the seal surface on the axle is smooth and polished. If its pitted at all the seal will probably leak again soon. if its pitted you can fill them with epoxy or JB weld and sand and polish again. Just be careful and use a verry fine grit paper!!!!
When its apart check and see what bearings you have. Stock is huge ball bearings, but if you replace it upgrade to some tapered roller bearings maybe. When you change to the roller bearing it eliminates the need for the seal because the bearing race has a seal on it already.
Just some things to think about when you tear it down. Might want to look what bearing the local shops have for you then go from there.
surfer-b
I dont like the A20's because everytime the seal goes the bearing has to also be replaced and with the quality of the aftermarket seals these days its not worth it. Some here like the A20's and yes they are stronger but I don't wheel hard or haul heavy loads so I'm going back to the stock type bearing and seal, my 76 had the OEM bearing and seals in it and never leaked. I upgraded to 31 spline axles I went with the A20 bearing set (tapered bearings) and have had to replace the seals/bearing twice just because of the seal leaking.
Timmy390
Conway, AR
Mine started as a small leak and quickly became a huge project to replace the housing ends. I found my axle bearings were spinning in the housing and the side that was leaking had an oblonged bearing cup in the end. No real repair options so I replaced the ends.
Not all axle seals are created equal. I took my calipers with me to the parts store and found differnt brands had different size openings for the axles to side through. I chose the "motor city" brand which is the advance auto house brand. They had the smallest hole thus fit the tighest on the axles.
Good advice from bknbronco on making sure the axles are seal surface is smooth.
Tim
Hozr
Rogue Valley, OR
Running rear drums? Could be a leaking wheel cylinder. Much simpler fix. How does it smell? Gear oil smells horrible.
bmc69
TarheelEB
TarheelEB
Update
I pulled the wheel off. It was a mess. Oil was everywhere. I pullled the axle and found that I need a new axle seal, new bearing, and definitely new brake shoes. The brake shoes were covered in oil. I ordered the large axle seal, large bearings, and brake shoes from Wild Horses. I needed the large axle seal and bearings because it is a 77 with a 9 inch rear end and 28 spline. I will post an update once I get the new parts delivered and put in. Thank you to all who have replied.
