Gray035
So my pinion seal has been leaking for some time and I went to change it this morning. When i separated the drive shaft from the yoke I wiggled the yoke to check the bearing and noticed that the nut securing the yoke into the rear end is loose enough to allow the yoke to wiggle behind the nut (otherwise it seems to be tight, which makes me think the bearing is okay?). What does this mean? Did the PO change out the seal and fail to tighten the bolt to spec? what do I need to do to fix it? Do I need to put a new crush sleeve in there? If yes, how do I know how tight to tighten the bolt once the new sleeve and seal are installed?
On a related note, there had always been a fair amount of vibration when I got the truck above 55 or so, and I thought it was just some play in the driveshaft and U-joints. I changed out the U-joints a couple months ago and now the one I just disconnected from the yoke has a bunch of broken and missing needle bearings (it should last longer than a couple months I think). Is it possible this was all caused by the mis-torqued yoke (If in fact that is what happened. Do crush sleeves ever just go bad and need replacing?) Any help would be great!! I'd like to fix the problem, but it would be helpful to know the cause so I can pre-empt it breaking again.
