GSP9
I'm in the process of replacing leaf springs and bushings. I was test fitting everything and the new bushings would not fit into the rear shackle. The new bushings are a hair too big. No way they're going to be forced in there. So I started looking and without having other stock shackles, it's hard to say but it almost looks like someone put a sleeve in the shackle at some point. If they did it was a long time ago and they're not coming out because it looks like they are welded along the one seam.
It looks like the bushings would fit if the sleeve were not in there. Can anyone confirm if these sleeves were added. I added two pics. I'm at a crossroads, if the sleeves were added then I'll just order new shackles. If nothing was added and the sleeves are original, then for some reason, the new rubber bushings are too large / wide to fit in there.
