with the aftermarket springs, many times if you have the open side to the back the center plate of the shackle hits the #2 spring as it travels. this is due to the added leafs over a stock 5 leaf set up. the centerline is the same on the shackle so you can turn it around no problem and avoid this.
might be a good time to think about stepping up to a set of Super Schackles.
shameless plug there...
