Blocks are only good if you're going for height. When you start adding traction bars, replacing u-joints, and possibly other parts then changing the entire spring pack isn't to expensive. The PO of mine had blocks for 5 1/2 inch lift. I put springs and tract bars because I still had some axle wrap. Later on I had to change the entire 3rd member due to the pinion bearing housing be broke. I don't care for blocks.
