Rear Quarter Interior Treatment
jckkys
The Ranger package had padded vinyl upholstery covering the interior of the rear quarters. If memory serves me, the backing was cardboard similar to the head liner. I'm thinking steel or aluminum sheet metal backing for carpet that matches the kit color would be more durable. It would also be a good mounting place for stereo speakers. Do any of the carpet kits offer matching material to carpet these panels? Also not being an audiophile I don't know if sheet metal is a good material to mount speakers on.
I think you can get the extra carpet and cut it yourself, but I don't think I've ever seen a pre-cut side kit offered.
But getting it at the same time as a carpet kit would guarantee at least a slightly better match than buying the extra carpet after the fact.
I think metal is not the best material for the speaker aspect, but I bet that if you treat it like any other body panel you want to "tone down" a bit, and add a sound deadening material like Dynamat or Lizard Skin (if you're spraying down the whole vehicle too, that's a good option) and maybe even stuff the interior cavity with some regular old insulation. Probably sound pretty good if you get it just right.
Good solid mounting would be a must of course, to keep any buzzing at bay. Maybe even to the point of letting the stick-on rubber stuff (whatever brand you choose) lay under the screws at the mounting points. Isolating the panel from any brackets.
I'm sure that's why MDF is chosen, as well as it's workability by the installer. But I think the metal would be good too, if enhanced with the other stuff.
Just like a door.
J
jckkys
I'm thinking a piece of plywood backing the aluminum and mounting the speaker to the wood. Most speaker boxes are wooden. I'll need a rugged speaker grill too. Body putty on the periphery of the aluminum should stop metal to metal buzzing.
myclsic69
For what it's worth category, I wasn't up for spending major coin on mine.
I had made cardboard templates and transferred the cut onto 1/8" Masonite(hardboard)
then found some nice Wimb. White upholstery fabric at a local chain store and Glued them up, a couple chrome decorative screws and I was in Business for under 40 bucks.
Other than the fancy stitching they look like the real McCoy.
I believe these are sturdy enough for speaker holes, But my speakers are mounted under the rear seat, out of site.
Rustytruck
Contact Melissa at Bronco Hut, they carry fiberglass side panels with speaker mounts built in. They have a great fiber glass product supplier.
Jfryjfry
I have a set of aluminum diamond plate rear quarter panels that we won’t be using if you’d be interested.
Scotty
If you go this route, definitely call Melissa BEFORE placing an order. Jay (the fiberglass guy) recently moved and has been getting caught up.
Steve83
In Frank's '75 EB eB, the door panels (with 6" speakers) were 2 layers of 1/4" hardboard; the bedwall panels (with 6x9s) were 1 layer, and the rear window surrounds were galvanized steel valley gutter from Lowe's or HD cut & hand-formed to slip behind the rubber window gasket. All were wrapped in the finest Wal-Mart naugahyde, but the hardboard panels also had ~1/8" batting.
(phone app link)
