Rear seat options
.94 OR
Willamette Valley, OR
I currently have a factory rear seat that is in good shape, but my kids have outgrown it.
What options do I have for sourcing a rear seat from a donor vehicle that does a pretty good job fitting the gap between the wheel wells and sits ok?
Years ago I thought I had found a thread of small 3rd row seats that might work but not sure how easily they may be to fab in. I showed the fold and tumble seat offered by the vendors to my wife and she wasn't too excited about it.
omureebe
I recovered a fold and tumble to mimic by interior and it looks like it belongs there.
kylakekevin
I used a TJ rear fold and tumble in mine and it fits perfect. I was able to use all the TJ brackets also. Only thing I had to change was the locking pins for the folding back, 6"x1/2" bolts took care of that.
broncomikem
I have a set of bucket seats that fold and tumble I picked up for a project(I don't remember what vehicle they came out of), They will fit perfectly between the fenders. They will need some fabrication to mount them. PM me your number and I can send some pictures.
jmangi62
I was looking at the jeep wrangler rear seats on flebay, but it looks like a trip to the local u pull it is in order. ;)
.94 OR
.94 OR
When/if I get that far, I plan on using a third row seat from a Ford Freestyle, hopeful track-mounted like in this spiffy thread, posted by Slowleak.
Nice seats. I like the rear headrests where they can be dropped down out of the way when not needed.
Do these have the external frame for the electric motor to rotate the seats into storage mode? How do you plan to work with or around that?
Howard2x4x4
No motor, I am hoping to use Slowleak's great suggestion and incorporate a hinge/pivot so that when they are in the far forward position with the backs folded down, I can tumble them.
KeithKinPhx
You might get lucky in Omaha but I checked the three biggest pull yards in Phoenix and not a single Jeep Wrangler or TJ in any of them.
I ended up ordering a blemish fold and tumble seat from Tom’s.
And then ordered a new 12” JBL subwoofer with amp and enclosure to go behind it. (JBL had them 50% off this morning)
TonyPDX
I used a 2 door JK rear seat and mounted it to MaxxTrax so I can adjust it fore/aft and remove it easily. it is a fold and tumble that barely fits between the wheel wells. The seat belt buckles are mounted to the seat in the center.
Tony
wsager
You remember the year on that Freestyle, Howard?
Thanks, Wayne (who graduated from beautiful Western Michigan University)
Howard2x4x4
2005 - 2009 Nice touch on the WMU mention Wayne! Spent a couple years there myself!
omureebe
Heh, looks great! You did it yourself?
Pics of my install here. http://www.classicbroncos.com/forums/showthread.php?t=226788
Holy crap... I’m pretty sure I read your post years ago and bought the seat from Amazon. I had a local guy recover it since that was beyond my skills, again a few years ago. Now I was at the point to finally install it since body work was done. A little snug with insulation and carpet but it looks and fits great. Too funny. Oh and thanks!
Nothing Special
I went with front buckets in the rear of my Bronco. I think they are Bestop Trailmax (it was a while ago...). They were a tight fit between the fenders (I think I had to cut off the knob on one side that adjusts the seat back angle). I made my own bracket that bolts to the original seat mount points.
The seats do stick up kind of high if you don't like the look, and they do block visibility a little (I'm used to it and it doesn't bother me). But they are pretty comfortable, even for adults. And with the high back to support your head in a collision and seat belts with shoulder harnesses, it was a big step up in safety as well.
picture.php
.94 OR
.94 OR
I ended up with a 3rd row seat from an Explorer (2006-2010), grey leather.
I'll need to modify the base but that part should be easy. The headrests fold down and the backs fold down flat too.
Pic is from ebay ad but mine are just like them.
.94 OR
.94 OR
Update:
Getting the frame built to support the seats. I mount my stereo amps under the backseat so I had to allow room for them plus balance the height of the sitting position. Huge improvement over stock plus I can fold them down when not in use to keep them out of the way for visibility.
Bitch'nBronco
Loose Cannon
Ringwood, NJ
I went with 06 Jeep Tj seats, they fit great and its nice to have the fold and tumble option
Sent from my SM-G973U using Tapatalk
