Rear shackle bushing
Southbronco1
Hello friends, I’m replacing my stock leaf springs. Several of you have already been very helpful as I do this. My latest problem is with the new shackle bushings. They are Polly bushings from Tom’s. While pressing them into the new shackles I needed to use a vice and a ton of force. Is this normal? They didn’t bulge or deform, but they stopped budging with about a 1/8” to go on the one side. I’ve attached a picture. I figured this was adequate, but now trying to install the shackle (with spring attached), and it won’t go into the hanger. If the bushing was completely flush in both sides it would make it easier I think. But I’m still not sure it would go in. Is this typically a hard install? Do I need to somehow spread the hanger a bit, and if so how? I have the open face of the shackle facing toward the back of the vehicle as Tom’s insisted. This is not a lift, but rather replacing stock leafs with stock 5 pack. New shackles. Any thought greatly appreciated.
Those are not stock shackles, so presumably Tom's also? If so then you would go by their instructions. Stock shackles absolutely go with the open face rearward, away from the leaf spring. With aftermarket shackles most(?) have the open face forward, toward the spring. I don't actually see a closed side on yours. Got a full pic?
But aside from that, which does not change the bushing issue, you're correct in thinking they should go in all the way. If you pull them out, can you size them up outside the tube? Meaning butt them up against each other to make sure that they are not so long that they are meeting up in the middle and interfering with the installation.
I have run into too-long bushings before, and this was the result. Just got even worse when you install the inner sleeve.
And speaking of inner sleeves, since these are not stock shackles I'm assuming there is no extra sleeving inside the tube. But had to ask...
You say it took a lot of force to get them in, but just when did they start to get hard? Was it installing the bushing halves themselves, or only when you got to the inner sleeve part?
When the bushings I had were too long, the bushings halves went in as expected, but smooshed out when installing the sleeve, which was extremely hard to do.
S
Southbronco1
Correct, they are not stock shackles, but rather ones from Tom’s. Picture attached to show the closed and open side. Also attaching a picture of the bushing along side the shackle, showing that they don’t seem too long for the shackle. You can even see a slight gap in the middle with the inner sleeve showing. As far as sleeves go, there is no extra sleeve that would go on the inside of the shackle. Only sleeve being on the inside of the bushing.
OK I see now. Interesting design, I haven’t seen that one before.
The bushings sure do seem to be the correct length. Only thing I can think of is that the two manufacturers weren’t on the same page for at least a partial run.
My guess is The Toms is using an existing bushing rather than having a brand new one made. Perhaps even a stock replacement shackle bushing. So the shackle should’ve been made to fit the bushing, rather than the other way around.
And the another guess would be that perhaps the powder coating is on the inside of the tube as well, which could easily explain a few extra thousandths of tightness.
Which is a lot for a poly bushing.
Of course it’s a weekend, so you can’t get a hold of them again most likely. But take a peek inside and if it’s fully powder coated that may be your answer.
Either another shackle without the coating, or a larger tube. Or bore the existing one out using some kind of a cylinder hone.
I meant to ask, is there an identifying number on one end of the bushing or the other?
For example a “3005“ could indicate a certain thing from a particular manufacturer.
We could compare those to other known shackle bushings. Even without the part number we could get measurements to compare.
S
Southbronco1
Thanks as always. I will check the bushing for number when I’m next back at the shop. And call Tom’s on monday.
Another question for clarification. Were the bushings themselves hard to push in, even before the center sleeve? Or was it the center sleeve giving all the grief and the need for a vise?
Poly bushings are usually able to be pushed in by hand. Firm, but easy. If they were hard then for sure inserting the inner sleeve will serve to deform (expand) them and you end up with a bushing that won't go in, or if it does, won't stay in. In those cases even if you did manage to get it to seat all the way to the shoulder somehow, it would literally push itself out slightly in just a few seconds.
Just asking questions to bide our time until you can find out more next week. I hate weekends sometime!
But it's also why I spend as much time as possible here in case I can answer a question about our own products when they come up.
jmhend
Honestly, I think it will fit (in a few of your pictures) the bushings have plenty of clearance. Have you tried just the rubber and not the center section? If not, try that. If the rubber fits then the spacer will fit (it takes lune and a lot of love).
I feel like it's a way to test my vocabulary.
Sent from my SM-N960U using Tapatalk
savage
Bronco Nut
Renton
I installed the Tom's shackles, you need to put a little silicone lube on them and they should install with out to much trouble. Plus you put some silicone lube on the metal sleeve and press it in, they were tight and a pain. The bushings went in for me with out to much problem. But the metal sleeve was a pain, I used a large c-clamp to press it in.
S
Southbronco1
Thanks guys, I actually pushed the one half of the bushing in with the center sleeve already within it. Then pushed the other half in. I put a bit of white lithium grease on both half’s of the bushing. Took the bench vice to get them in a far as I did. I haven’t done the passenger side yet, so I will try just putting the bushings in first and then push the inner sleeve in after to see if that makes a difference. Thank you all
S
Southbronco1
Sorry forgot the pic
S
Southbronco1
On the passenger side Shackle I inserted the bushing halves first and then the inner sleeve and that worked great and everything went flush. Now trying to install on passenger hanger and still impossible to get into hanger, but not done trying. Back on driver side, I will have to contend with that bushing being 1/8” out as I doubt that those bushings will pull out.
As it relates to both sides, wondering if there is a way to spread the hanger just slightly to let the shackles drop in easier. Thoughts?
You should be able to get the bushings out by pounding the sleeve out first. And since the second one went together much easier you could then put the first one back together using the same method.
It’s relatively easy to spread the ears on the frame hangers at both ends but especially the rear where the shackle goes by simply putting a big adjustable wrench on the edge flange and use it as a lever to pull out. You don’t really want to go too far out of true though so it’s better to make the bushing fit the hanger, rather than the hanger fit the improperly seated bushing.
S
Southbronco1
Ok thanks. I was thinking that I could spread the flange slightly to get the shackle in and the release it and it would return to its normal posting. Not permanently bending it apart.
don’t know if this is even possible.
savage
Bronco Nut
Renton
I made a spreader out of 1/2 inch bolt 4 1/2 inches long,4 grade 8 washers, and 2 grade 8 nuts. It worked great for me and it didn't hurt the hanger.
Spreading the ears is pretty easy (that’s a great tool and method savage) but it doesn’t spring back. When you move it more than just a little it stays moved.
savage
Bronco Nut
Renton
I do it a little at a time to just get it to slide, still has a little resistance.;)
