Rear Wheel seal replacement help?
stingus
Nashville,
Need to replace my rear wheel seal and can't figure out my axle lb. Looked on drivers side and the numbers were Front: 2260 Rear:2546
Neither of these match up with the seals i find available.
What am i missing?
Also, any step by step help on replacing this rear wheel seal would be appreciated since I'm learning as i go.
Thanks!
Bronco_69
Monette Ar
pull the wheel off. pull the brake hub off, remove the 4 bolts holding the axle flange on. pull the axle out, replace seal, put it back together.
i would replace the axle bearing at the same time.
Viperwolf1
electron whisperer
Could be light duty or medium duty ('74-'75) axle. Medium duty uses the heavy duty bearing and seal.
