rebuilding steering box
mash
ok while doin this the bearings fell out, shit! I now have the box completely apart anyone know if i there are better/ more complete directions to put this thing back together?
thanks
josh
ORBronco
Springfield, OR
you ought to be able to feed the ball bearings back in - just remove the cover from the hole on the side, and feed them in. you'll be able to get them all in by working the worm gear in and out CAREFULLY, so you don't pull it out too far
good luck
Viperwolf1
electron whisperer
Don't just put them back. There are two different sizes and they need to be alternated. If you clean them very well and put them under good light you'll see that exactly half are bright and the other half are darker. This corresponds to the sizes. Once you fill the worm and nut with the balls use grease to hold the rest in the ball return tube.
bmc69
What...??? You freak..I been puttin them back for longer than you been borned and never knew about that.
bushman_22
Aloha, OR
That depends on the gearbox. Some are two different sizes and some are all the same. My 78 1/2 ton box are all the same. The Dakota gearbox we just did were two different sizes.
Bushman
Viperwolf1
electron whisperer
A little more book learning might do you old folk some good, if you can find your readin specticals. ;)
broncodriver99
Glen Allen, VA
Crap now I gotta go take my steering box back apart. It would have been really great if FORD had mentioned something about this in their F***ING service manual.
Viperwolf1
electron whisperer
Bushman
That might be true. Every saginaw box (stock Bronco) I've been in has two sizes.
Viperwolf1
electron whisperer
So what about the ford boxes? 4X4X2 box? Anyone know? Only thing worse than pulling a freshly rebuilt box apart cause you may have messed up is finding out after that you didn't need to.
Give me a few minutes to look it up. I have to find my readin specticals. %)
Viperwolf1
electron whisperer
No mention of different sizes in the manual for the Ford integral PS box.
00gyrhed
4x4x2
OK, first of all they are not all that way and I too have built several saginaw boxes and put them together without regard for the ball size. I got over 100K on a chevy box I put in a CJ5 that is still working. When I did my 4X4X2 box a pretty good set of instuctions came with the rebuild kit I bought at NAPA. It of course did not address the difference in ball size. I just had to call my old man (79 years old and NEVER bought anything new he could rebuild) and asjk him if he had ever heard of such a thing? He says Brondriver99 is full of crap or maybe hes working on Jap parts. But thats the old man talking not me so don't flame me, I am always willing to learn something new. :)
Anyway I put my 4X4X2 box together without regard for ball sizes and it works just great after 10K miles. I also went to the instructions that came with the brebuild kit and it says to feed the balls in and does not adress a difference in size. In fact it says you may have to rotate the shaft clockwise and then counter clockwise to get all the balls in. That pretty much means no one is expecting you to alternate ball sizes.
broncodriver99
Glen Allen, VA
WTF? You drunk? I simply asked if the Ford boxes had two different balls like the saginaw boxes? I had the instructions that came with the rebuild kit as well as a Ford service manual and saw no mention of it, but wanted to double check as the OP did not specify it was a saginaw box he was rebuilding.
Once again Viperwolf came through with an answer. :)
scbronco
Sumter, SC
if its any consolation, i just watched an episode of musclecar the other day where they go through the saginaw rebuild start to finish. they also noted a difference in the ball size, and said to be sure and alternate them... i know many folks dont hold these shows in very high regard, but they hafe seldom let me down in their instructional segments...
00gyrhed
aparently i can not read
so very sorry.
bushman_22
Aloha, OR
Ok I should have mentioned the dakota box was a saginaw the 4x4x2 box is a ford box. The ford boxes in the 1/2 ton form that we use for the 4x4x2 conversion have the same size balls. Most saginaws have different size balls. The reason for the different size balls is so that not every ball has a load on it scrubbing against the next ball. Even if you got them out of order it would probably still work, unless you installed all the small ones in and then the big ones. How long would it work would depend on how many balls were out of order. Like I said the boxes we are using for the 4x4x2 conversion are all the same size. I verified this by calling Prosteering also.
Bushman
