Rebuilt C-4
NC-Fordguy
Bethel/Greenville NC
Guys,
I rebuilt the c-4...new steel clutches, kevlar bands, new pump, had a shop rebuild the torque converter.
Every once in a while there is a long shift from 2nd into 3rd. Not as smooth as I think it should be. Doesn't seem to be any particular time this happens. It's just random. Doesn't matter if it is at high rpms or low, hot or cold.
I've put about 250 miles on the rebuild so far, fluid looks good and is full.
Any ideas?
Ed
BwoncoHowie
C-4 Wizard
You might have a particle or burr stuck in a shift valve, governor valve, or modulator valve. It may work its way out on its own or it might need to be cleaned out. A good help for this would be a magnet in the pan.
Did you flush your cooler lines before you installed the rebuilt trans?
NC-Fordguy
NC-Fordguy
Yea....I flushed out Everything Should I put a few hundred more miles on this and change the filter?? I really want to avoid pulling the tranny out again...almost as much un-fun as moving
