Bronc937
- Sep 22, 2011
- 78
This is long winded so I apologize.....
I'm just finishing the build on my '77, with a C4, and during test drives it won't shift up into third. I thought it was the kickdown linkage so I disconnected it. No up shift. Then I checked to make sure I was making good vacuum at the manifold for the modulator and good pull. Also checked fluid level too.
Here's the funny part... It won't shift up in drive but when I put the lever in "2", it shifts up to third. What the (bleep)!!!
I figured it was probably the valve body so I took it back to the shop that rebuilt the whole transmission and the mechanic said it checked out fine and suspects I have the kickdown linkage set up wrong. He cited that partial pressure on it causes a malfunction.
Today I put it back together and still the same problem. I'm dying to drive this thing. Please help!
