Recommended fuel pump?
brambo2008
Fresno
I have a Edelbrock 1405 Performer 600 CFM Square Bore 4-Barrel Air Valve Secondary Manual Choke carb. I was having a problem where when I was up to about 60 it would feel like I was running out of gas so I put a new fuel pump ( 4 to 8 psi), fuel regulator and a new ignition module. It ran good for a couple of day then it happenend again, Like I was running out of gas? Please let me know if I am wrong but I think I need a bigger fuel pump. One that put out a least 10-16 psi?? Please let me know what you think and what kind of pump should I run?
Thanks...
Oatmeal
It should run fine with a stock fuel pump. You probably have some sort of fuel line restriction. Check your tank pickup screens, if they're missing, they've probably fallen apart and are creating a clog somewhere. In my case it was the fuel tank selector valve. It was all clogged up with junk (missing fuel tank pickup screen%) ).........it would run fine until you put a real load on it (like pulling a steep grade with your foot into it) and then, it would start missing like it was fuel starved.......which it was:eek: took it apart and cleaned it and all was fine. And if you offroad that thing at all, you wouldn't want 10-16 psi of fuel pressure. I use an adjustable regulator and cut the pressure down to about 3-4 psi off road. BTW I have that exact same carburator and hate it......one of these days I'll gather up the rest of the parts to finish my GM TBI conversion----------Hans
B
brambo2008
Fresno
Fuel pump
The pump that I am using is a Airtex 12 volt 5 to 9 psi electric pump. I guess I will check the fuel tank selector valve. Is the tank pickup screens on the sending unit, because my sending is not giving me a reading on the main tank!
Maybe thats a problem? The funning thing about it it doing it on both tanks??
Let me know what you think. Thanks oatmeal!!;D
broncnaz
X2 on pickup screens they could be clogged up. You may also want to check or replace your gas caps as time goes by the vents in then tend not to work as they should so they may not be allowing enough air into the tank witch can create a vacuum on the fuel and wont let it go to the carb. Also check your fuel lines for cracks you could be sucking air causing the lean condtion if in doubt replace any rubber lines. I would also suspect your fuel regulator many times they are junk If you dont have a guage in line to tell you how much pressure you have try removing it see if it still cuts out. The only other thing that could happen is that the secondaires are opening to soon and causing it to stumble at high speed.
Stock fuel pump should be fine or any pump that runs between 4-8 psi. I've heard many edelbrocks having issues with higher pressures. For electrics I like carter P4070's.
B
brambo2008
Fresno
Steel line
How much of a difference would it make if I replaced my current haalf steel and rubber gas line to all steel?
broncnaz
Shouldnt make much of a differance unless your currentlines are leaking. One more thing if I remember correctly the 1405 carb is setup leaner than the 1406's you may be running to lean might want to check your spark plugs you may have to rejet the carb to fix the surge.
Oatmeal
I think it's the other way around, the 1405 uses a manual choke and is set up more for power versus economy.......I wish I would have known that when i bought mine 20+ years ago%) because gas mileage sucked when I had it on my 302 and yes, you're right you might have to rejet to get it just right. I got the tuning kit when I bought the carb and really had it dialed in......it really romped on the pavement it just didn't like off road off camber situations much%)---------Hans
broncnaz
Yeah your right I knew one was setup leaner. 1406 is the leaner one. either way jetting needs to be checked.
B
brambo2008
Fresno
Well, Today I had the same problem I had two months ago. Was driving and just died! Let it sit for about a hour and fired up?? What I have done to my edlebrock carb over those two month is changed the sending unit, adjusted the floats five and a half turns, changed all the hoses and most of the clamps, new fuel pump etc etc etc!!! The guy that I got it from was running it with out a air filter and the floats were out almost all the way out?? Is there a chance that this carb (edelbrock 1405) is bad and needs replaced? What carb do you recommmend (everyday driver)? Is there something I am doing wrong? Almost forgot, when I did adjust to five and a half turns it did good and then the next morning i went in to go to the store and didn't smell gas but when I got in the EB you could smell gas on the driver side?? I walked around and open the hood and couldn't smell anything?? Thanks for anyones help on this!
blubuckaroo
Grease Monkey
Ridgefield WA
http://www.edelbrock.com/
If you use this Edelbrock link, you will get a ton of info for that carb. The only real difference between the 1405 and 1406 is the way they are equiped. with the metering rods, jets, and pull up springs. Most of that stuff usually gets changed out when you dial it in correctly anyway. You can't expect much if you just pull it out of the box and install it. Take a little time with it after reading the dope and watching the videos.;) However, I don't think the carb is your problem. Even a totally out of tune carb wouldn't just stop in the middle of the road. Why don't you try unhooking the fuel line to the fuel pump, and put some air pressure into the fuel tank with an air hose sealed with a rag. If there are no restrictions, you should get a good stream of fuel.
broncnaz
Your current carb should be fine for street use. I dont think the dying issue is related to the carb itself.
As for your adjusting the floats edelbrock carbs dont have floats that are adjusted with screws you have to open the carb up to adjust tehem you must be adjusting the idle mixture.
You really need to get the instructions as dirtdonk has linked for you and follow them then see how it reacts.
There are other things that can cause the dying issue like the igniton module is going bad or you have a bad wire somewhere that occasinally grounds out and kills the engine.
Oatmeal
........Was driving and just died! Let it sit for about a hour and fired up??........
What year Bronco? Does it have a Duraspark ignition? When the module in my '74 was going out, it would do just that and before it got to that point, it would buck and miss (on occasion) like it was running out of gas. Just something to think about--------Hans
B
brambo2008
Fresno
The EB is a 74. I willget a copy of the manual and read up on it. What wire do you think I should check?
Thanks for all the help!!!!
blubuckaroo
Grease Monkey
Ridgefield WA
Hey!
You've got me mixed up with DirtyDonk!:mad:
Oatmeal
I would check the pickup coil inside the distributor (don't normally fail but, might cause those symptoms if it was on it's way out) and your ignition coil as well, make sure it's NOT getting 12 volts as it should be fed through a resistor wire to cut the voltage down.......might be overheating. You should be able to find trouble shooting procedures in a good repair manual so, you don't waste money replacing any unnecessary parts.-----------Hans
