Optima Data
Ok, some of you that know me were probably dreading this, but hey, that's never stopped me before, right?
I spent yesterday crawling all over the pallets of Optima batteries at one of the warehouses I frequent and checked out the data tags on them for some updated info. And I figured I'd just sort of pass it on. I probably could have gotten the book or called the factory, but that'd be too easy. And not near as much fun.
If it's too much info, stop me if you can...
Some common spec's for each category:
All 12v Red Tops have a 3 year free replacement warranty. After that it's pro-rated for the rest of the warranty period.
All full-size Red Tops are rated at 800 CCA's and 980 CA's and have a 110 min. RC (reserve capacity). All the compact ones are rated at 720 CCA and 910 CA and have a 90 min. RC. All are starting type batteries. All had black "six-pack" cases but the smaller ones had squared-off bases and tops. Probably for ease of mounting.
All Yellow Tops have a 1 year replacement warranty and are all Deep-Cycle types. The full-size ones are rated at 750 CCA's and 870 CA's and 120 min. RC and a 55ah rating. The smaller 51 series are rated at 500 CCA's and 625 CA's and 70 min. RC and 41ah. All had gray bodies. The full-size ones had the traditional "six-pack" bodies while the Group 51's had smooth rectangular shapes.
All Blue Tops have an 18 month free replacement period. The starting version is the same 800 CCA and 980 CA and 110 RC as the Reds and is additionally rated at 50ah (amp-hour). The Deep-Cycle version is 750 CCA, 870 CA and 120 RC like the full-size Yellow's and is rated at 55ah. I didn't see any compact Marine versions. All were black six-pack cases. Didn't see any gray cases like before. Even on the Deep-Cycle ones.
I didn't make it to the big mamma-jamma Group 31 pallet and never saw any of the old Orange Tops so don't have any info on either.
For identification purposes, the part numbers and descriptions are:
Red Tops:
8002-002 - Group 34 (fullsize) w/black case and no side terminals.
8003-151 - Group R34 same as 34 but with reversed terminals.
8004-003 - Same as above but with top AND side terminals.
8020-164 - Group 35 (compact) w/ removeable top "cap" for
retaining stock type hold downs (I think). Black
case. Top terminals only.
8022-091 - Group 75/35 same as above with side terminals.
8025-160 - Group 25 no side terminals.
Yellow Tops:
8012-021 - Group D34 (full-size)
8014-045 - Group D34/78 (f.s.)
8071-167 - Group D51 (compact)
8073-167 - Group D51R (compact) Reversed terminal layout. I
didn't note whether they had side terminals or not,
but I thought they did.
Blue Tops:
8006-006 - Group 34M w/marine terminal layout. No side posts.
8016-103 - Group D34M same as above. Deep Cycle.
There may be more batteries in the lineup but these are the only ones I saw.
I know I tend to write novels and take up bandwidth, but SOMEBODY, SOMEWHERE will hopefully find this information useful. If not I can always go back and delete it!
Happy referencing.
