But R134a (which you will probably be using) is known to have some small bubbles in the sight glass even at the correct charge.
I go off superheat method (I think that is the correct name for it). You look at the low side pressure and the low side temperature of the suction line going into the compressor. For a given pressure there is a temperature the refrigerant will boil at. When you get down to 5-7° above the boil point at the pressure, you are full. Any more and you risk pulling liquid into the compressor, that is bad. You can hydrolock a compressor like an engine. If it doesn't go boom, it tends to damage the valves in the compressor.
