jkransbottom
Work and family obligations have finally slowed enough to give me a chance to do some work on the Bronco. I'm trying to reinstall the rear axles after having new bearings installed and I can't get either side to go in all the way. I've been slightly removing and turning the axles a little at a time to try and find the right spot to get the splines to mesh and I can't seem to find it on either side. The drive shaft is still disconnected from when I removed the third member to drain the gear oil. Would it be better to have the driveshaft attached and in park so the gears won't turn? Any other ideas or tricks? TIA.
