Remote reservoir for explorer PS pump
JWMcCrary
Found this reservoir at Summit, considering adding this while doing the front explorer dress swap. Thinking I can drill the side of this tank an add a 2nd return to do away with the T I have in my current setup with hydroboost.
Thoughts?
https://www.summitracing.com/parts/mor-63490
duffymahoney
This guy makes custom stainless reservoir tanks for the explorer front dress, you just tell him the fitting size and amounts and it bolts right on. He has made a bunch of them.
jac_specialties@yahoo.com
mustanggarage
I am using that same reservoir on my 408 build. I had to locate it back a ways in order to clear the hood reinforcement and the ac compressor but I think it will work well
mustanggarage
I don’t know yet lol. About 1 I would say but I haven’t filled it yet. I just got a reply from toms broncos. I asked them what fluid I should use with there 3.75:1 box. And I will have to pull the steering box again when I pull the body back off also.
nvrstuk
PNW
IF you do ANY 4 wheeling and not just a mall crawler do not mount the reservoir on the firewall. Reason is if you are climbing a steep rock wall or whatever, the fluid level would be below the inlet of the pump when you mount the reservoir to the firewall or fender or ...
Several manufacturers are adamant about reservoir location and say so in their tech writeups. 14" long inlet hose is maximum length for PSC. The longer the line, the more friction and flow losses... it all adds up.
This is very common with the Exploder pump mount location since the pump sits so high.
Just a heads up.
Qumanchew
Kutztown PA
Just a heads up.
I'm getting ready to install one and that's something that never crossed my mind. Thanks for the heads up!
bmc69
I mounted mine on the inner fender.
JWMcCrary
JWMcCrary
Your link landed me on the last page of your thread, can you repost the pics here?
JWMcCrary
JWMcCrary
Thanks, that's exactly what i need. I tried to contact him with the email that was posted but so far no luck.
duffymahoney
He will get back to you.
Pages 40-42 of my build has pictures of the tank mounted.
