I just did this. Just tweak the tabs a little. Just enough so there is a gap between the tab and door frame. I started on the back, vertical post. This allows you to pop off the peices as the overlap each other. I then used a very blunt, large screw driver and a small rubber mallet. One edge of the trip peice wraps around the door frame a lot- the other edge not so much. I think the edge with lesser wrap is on the outside of the circle. In other words. Standing between the bronco and the open door, start with the rear most trim peice and the rear most edge of the trim. Just tap along the lenght of the trim peice and you will see it move a little as the trim trys to "pop" off the door frame. As you work down the trim peice, it starts to come off. As you near the end of the trim peice, get ready to catch it as it springs off the frame. Real easy. No bends or scratches when I did mine.
