Removing fan pulley?
G
Guest
Guest
theres just 4 bolts in front of the fan that are hard to reach knuckle buster so take your time 1/2 wrench and becareful of the radiator
brian72
brian72
Early Bronco Student
From the picture the radiator is out. Fan is off and only the pulley is left. The four bolts that held the fan on were basically just long enough to attach to the spacer on the pulley.
But the removal of the pulley??? HELP ???
LSUpete
Brian,
It should fall off, because nothing is holding it on. It's probably just a little rusty, so just try to tap it lighty toward the grill.
