Help removing Explorer Fan Clutch
Ed74
San Diego, CA
I am having the absolute most difficult time breaking the nut loose. I am using a 36mm wrench along with a strap wrench to hold the pulley. I even tried to heat the nut to expand it enough to break it loose. I am about ready to take a sawzall to it and cut it off!!!! Any suggestions would be greatly appreciated.
Thanks,
Ed
E
Ed74
San Diego, CA
Thanks needabronco. My 36mm wrench is part of a two piece fan clutch removal tool, which I purchased from Kragen. I am using a strap wrench on the pulley because the other piece, which slides over the 4 bolts, is too small. Strange how the wrench fits but not the other part?
Initially, I rented the fan clutch tools from autozone. However, I soon realized none of the wrenches fit. I think the smallest one is 40mm. So far I am out of options.
bigmuddy
Marthasville Missouri
I had one helluva a time removing mine. I ended up taking the pulley and fan off the engine and sticking it a vise then spraying it down with PB blaster. It took a tremendous amount of force to spin it off. I cannot remember which way it spun off but once I got it moving it easily came off.
Good luck,
Ben
E
Ed74
San Diego, CA
I also soaked the nut with PB blaster. Unfortunately, it did not work. Should I spray it down again and wait a couple days? I was attempting to rotate the nut counter clockwise while facing the front of the engine.
E
Ed74
San Diego, CA
Ben,
How did you remove the pulley and fan off the engine without removing the pump?
Thanks,
Ed
Viperwolf1
electron whisperer
It's right hand threaded. Lefty loosey-righty tighty. I took a 1 in. by 1/8 in. by 2 ft. piece of scrap metal, drilled 2 holes in it to match the pulley bolt spacing, and put the pulley bolts through it to hold the pulley from turning.
mattt
The Autozone near me had two different fan clutch tools. The first one didn't fit. Then I went back with the fan/clutch assy. They have a second one that says it fits I-6 engines. I don't exactly remember, but I used some combo of holders and wrench from both tool kits and got mine off using them. The hex wrench was a bit large/oversized, but it did remove the clutch from the waterpump snout.
Bronco Brian
Try hitting the wrench with a hammer to shock it, That is how I did my Powerstroke worked well
Brian
toddz69
Thanks,
Ed
There's also a tool that you can get at Napa that holds two of the bolts on the pulley/pump. It's pretty long so you can get a lot of leverage. I'd recommend buying it if you have the serpentine setup because you'll need it from time to time.
Todd Z.
A4x4Junky
South Jersey
Todd Z.
I tried this tool and still got my butt kicked. Some are just really stuck I think. Got irritated and finally unbolted the waterpump and decided Ill just replace em.
Anthony
Viperwolf1
electron whisperer
That's funny mine's not reverse and neither is my spare waterpump.
Viperwolf1
electron whisperer
It's a reverse direction fan and wp but the threads are right-hand. That keeps it tight when the engine is running.
E
Ed74
San Diego, CA
Thanks everyone for your help. My chilton manual says the manufacture did not specify the thread direction. However, if I remember correctly, my Haynes says to loosen to the left.
It seems as if my assembly does not quite match the pictures within the manuals. The fan clutch has a long shaft that attaches to the water pump pulley. Is this correct? Are the fan clutch threads located at the clutch side (where the nut is) or the pulley side?
Thanks,
Ed
Viperwolf1
electron whisperer
Well, both sides. WP is the male side, big nut is female.
