Hi Again,
So far this 1971 Bronco has been a great learning experience.
Since being transported to me, the Bronco has only been driven once. The shakedown cruise was enough to start a fairly long list of repairs. (Besides the front driveshaft falling out at the transfer case, and the exhaust fumes being so bad in the cab that I still smelled exhaust fumes two days later, the steering was so bad that it was difficult to keep it between the lines on the county roads.)
At the recommendation of a fellow off-roader, I purchased a Borgeson replacement for the lower shaft and rag joint. (To say that the rag joint was shot is a gross understatement.)
I have searched but have yet to find much information on removing the lower shaft. (This Bronco has a 2-piece shaft and power steering.)
I have removed the bolt that runs through the coupling at the steering box. (With the welded hoops for the shocks and other mods done by the previous owner, I wondered if removing that bolt would be possible.... It was tough.) I have also removed the bolt that secures the top of the rag joint assembly to the upper shaft.
There isn't much left to the rag joint, so I could just pry everything apart at that point; but, with the brake lines and air locker plumbing close to that rag joint, I will need to be pretty careful.
I'm not even sure if separating the lower shaft from the upper shaft at that point is the right thing to do.
Am I going about this the right way, or, is there a better way to get the two shaft halves apart? (I was reading another thread that talked about pulling the steering wheel/upper shaft into the cab to separate everything. I'm not sure if this applies here.)
Thanks again for any advice that can be offered.
Jeff
Jeff
