Removing steering shaft joint - 76-77
joshd1971bronco
Oklahoma City, OK
Needing to remove the factory lower spliined joint from my 76 power steering lower shaft to make way for a new Delphi box and adapter.
There's no set screw or obvious way to disassemble this easily. Before I go to whacking on it with a sledge, thought I'd ask and make sure this just needs some serious persuasion before I go to beating on it.
One pic of my shaft in the Bronco, another pic of an identical one I have laying around.
Do I just muscle it off there?
Thanks!!!
I'd rather be driving my Bronco
J
joshd1971bronco
Oklahoma City, OK
Maybe it's not real obvious from the pic, but there is no bolt or set screw holding that joint on the shaft. Maybe it's just a tight press fit?
And I'm trying to get the joint off the steering shaft itself so I can replace it with an adapter. I'm not trying to get the shaft off the steering box. Hope that makes sense.
Actually you are supposed to be getting it off the box. Makes everything easier.
The bolt he mentioned is the one in the pic clamping and locating the lower yoke/joint on to the box shaft.
The attachment of the joint to the lower steering shaft is not likely to come loose from persuasion sitting there in the corner of your engine compartment. In fact, it's possible that it's been welded.
I know members here have fiddled with their '76 and '77 steering shafts, so maybe they'll have more hints and recommendations, but it's not going to come off willingly until you get it out on the bench where you can work on it.
The shaft may also resist sliding up into the female shaft. I think there is a nylon pin that has been melted/welded into the interface to keep them in position. That takes some extra effort to get the two parts to slide in and out with each other too.
J
joshd1971bronco
Oklahoma City, OK
Thanks, Paul. I am TOTALLY planning on having the steering shaft OUT of the Bronco before attempting to remove the joint. I was just curious if there was a well known secret to getting that joint off the shaft.
Perhaps some heat, or PB Blaster or some combination thereof with a lot of force will knock it loose.
J
joshd1971bronco
Oklahoma City, OK
Just in case it helps someone else I the future - yes, you just persuade it off the end of the shaft with a lot of force.
I clamped it in the vice, put some heat to it, and went to smacking it with a hammer. It came off slowly.
Ready for my new joint now.
Rocko1012
Shaft
I know I am late to this thread. I had cut mine off with angle grinder and cutoff wheel. What are you using to replace that joint? Are you keeping rag joint on top.
J
joshd1971bronco
Oklahoma City, OK
One of the vendors sells a joint to adapt the splined end of the stock bronco steering shaft to the new Delphi box I decided on.
It looks very similar to most of the aftermarket joints out there.
