Removing Wiper mount from Windshield
jake2077
I've searched through the forums but didn't see the exact answer to this question. I am stripping down the front windshield frame for paint and cannot figure out how to remove the wiper rod mount. Seems like there is a trick to it?
NicksTrix
unbolt it. the linkage stays on the arms. linkage has a clip that holds it to the motor arm which is bolt on as well. don't loose the slip if you opt to take it off.
jake2077
jake2077
Thanks, I'll give it a try here shortly.
Sent from my Pixel 3 using Tapatalk
jake2077
jake2077
That was it. The outside washers were hard to tell if they were part of the metal but eventually broke off and the unit came out. Thanks!
