what does the lower door post look like. I have this exact issue right now. I am cutting the lower portion of the door post off and putting in new kick plates. The rust is most likely eating away at the pillar from the looks of your picture.
I wouldn't even be real concerned with that, That piece of metal(kick panel) is actually samwhiched between the inner rocker and door post. I would take a cut off wheel and just cut a square section out removing that little swiss cheese section and patch it. the metal below looks fine. Make template if your replacement piece out of tag board then place it over that area and trace around it so you know where to cut. I'd just use a spot weld cutter where it's attached to the door post
