Repairable post?
apachetech
Mountain Home, Idaho
Is this damaged beyond repair?
rustbucket
Hard to tell from that picture. Especially since the carpet is still in place. We need some shots from other angles, as well. There isn't much that can't be repaired with skill, though.
71massbronco
I would bet dollars to donuts that there is more to this trouble spot then this visible problem. One thing about eb's i've learned in the short time I have worked on them, they rust from the bottom up. ;)
Stutsmo
Yea we need to see a few more angles. what does the front of the rear door post look like?
Apogee
Tangent, OR
My experience is that they rust bottom up, top down, front to back and back to front first...there's a small patch directly over the transfercase that seems to hold up pretty well.
apachetech
apachetech
Picture #1 is the passenger side front post. The other two pictures are from the driver's side.
pcf_mark
Looks very repairable from these photos and I would section/piece it. BUT as a great prophet stated earlier they usually start rusting from the bottom unless yours is focused in an area the door leaked. If the inner rocker and floor look good from the bottom you can fix this easy peasy lemon squeesy.
beaux312
Hartford, AL
oh yes you can fix that. Get a hand held sand blaster and tha will show you how big of a problem you have. I would check the inner rocker also
sellitall
Malvern, Pennsylva
That section is definitely a "can of worms" area for broncos. You have the striker welded to that inner support which both have rust. The extension panel usually rots where it meets the inner 1/4 panel. If that's not enough, the 1/4 will tend to rot where it meets the inner wheel well.
Like someone mentioned earlier, get a spot blaster. It will paint a better picture of what you have going on. Also, look inside from the backside of the front part of the 1/4 panel. If the striker appears to be ok except for the section you posted a pic of, the rapair will be fairly easy. If you see it lower on the striker as well, you more than likely have it on the inner rocker which makes it a bretty big repair job.
These pics show what I'm working with. I will have to get a tetnus shot when I'm done.
If you're lucky, and it's just in those two spots I would either fab up those sections or purchase the complete inner support piece from any of the vendors (I think they are about $22 or so) and graft it into yours.
apachetech
apachetech
Wow! Sellitall, yours is definatley is worse shape! That makes me feel much better! I am going to start pulling the homemade household carpet job out and get to looking for more areas of potential rust damage.
sellitall
Malvern, Pennsylva
Actually from this pic it looks about the same if not better than yours. That's why it's a can of worms.
You should see where I'm at with my upper floor. Pray to the heavens above you don't have to replace that section. I've gone through about eigth spot weld cutters and ten zip wheel discs. I'm getting there though.
Justafordguy
Yeah, and that's only because the T-cases all leak oil.;D
sellitall
Malvern, Pennsylva
I think you are right on that. Here's a video of my 74 I'm restoring. you can see just how clean the channel and metal underneath the tranny hump is. It's amazing because they didn't even shoot it with primer from the factory. I guess a leaky tcase/tranny/motor is sometimes a bonus.;D
[youtube]osZQvuF3PDk[/youtube]
grant_71
That is because the grease from the CV joint flings off and
protects the body in that area!
