- Dec 31, 2015
- 1,992
Little backstory. Been chasing a thermostat leak on stock 302 since doing a radiator flush. Checked intake face (straight). Sanded slight bend on housing, resurfaced recess where thermostat (Motorcraft #RT-1139) sits to ensure it was below face of housing.
After several rounds with different gaskets, Gasgacinch, ziptie to hold the Tstat in place etc, (dang I despise that one bolt) thought finally had it fixed. Stayed dry after test run, gave one last swipe under the housing before going for celebratory drive and yep, came up with coolant![Pouting face :rage: 😡](https://cdn.jsdelivr.net/joypixels/assets/6.6/png/unicode/64/1f621.png)
A video revealed the culprit - a porous place in the casting.
Leads to the main question - which (non-threaded) replacement housing/vendor has anyone found as a suitable replacement? Really only want to do this one more time....
Thanks in advance!
Thanks in advance!
