I have a '77, and the Dana 44 front axle is finally going to be rebuilt. I have the original Inverted Y tie rod linkage, everything is tight and none of the tie rod ends needs replacing. I know that that design has always been considered a bit weak, and I'm thinking I might replace the current tie rod with something better while I'm doing the axle... but what.
My Bronco has power steering and original front discs, a 2-1/2" lift, and 30's. It is a daily driver that also goes out for some fun in the hills. It will never be a rock crawling boulder jumper. Maybe the original equipment will work fine, but it seems like the perfect time to do an upgrade. Happy to hear your suggestions, comments, and thoughts. TIA!
