Replacing Drivers side Floor pan
ZuperDave
Hanford, Ca
Well, there is no turning back now,...I have cut away most of the cancer and am now cleaning the edges to reinstall some fresh metal.
This is what was cut out, it appears the previous owner did some patch work over the old stuff once before and with my project I wanted a fresh start.
Notice I was careful in not to damnage the cross support. I will have to grind some of the spot welds to get the old layers of skin off the cross support.
Here is the new skin that will be welded back into place before coating the whole tub.
GraficO
Albuquerque, NM
lookin' good so far... pans are a b&*%$... but the results are always so much nicer!
Just be glad you're not doing the cowl or the posts... that are hellacious!
4x4babygirl
Bronco Goddess
Tanasi
Are you gonna do the passenger side too? I found it was easiest just to do them both at once, while I was doing it and all.
jjwtwice
IGH, MN
Looks good. I'm going to be knee deep in shet metal replacement here soon. When all is said and done I will have replaced the cowl, both front door pilars, both door sills and rocker panels, driver side floor panels, passenger floor panels, front seat area floor panel, both kick panels, and that's what I can see. Some might say why not just get a new tub, well I thought I was getting a good one until I stripped it down, you should have seen the rust pour out. Any way it will be new when I get done and I need something to do.
ZuperDave
ZuperDave
Hanford, Ca
The passanger side was done already, looks pretty good. I'm lucky the cancer has not spread to far, I only have to replace the drivers side. Everything else is good and the whole thing will be coated with Por15 soon.
I will take pics as I proceed.
ZuperDave
ZuperDave
Hanford, Ca
Well, Minor set back. Time Out was called tonight when I found that the "New" Floor insert is not fitting correctly.
The width is right on, but the length is off. There is a predrilled and stamped impression where the body mount bolt goes through. Well it is about an inch off. The "new" floor pan need to go back about an inch, but there is a pre-bent tab on the back that is to be welded to the metal below the drivers seat area.
My options are:
flatten the tab out and re-bend it to the correct spot.
-or-
run the floor pan under the wall and have the tab on the backside.
I will take pictures, because they are worth a thousand words
Tuff68
Hermitage, TN
The floor pan I made came out long and I put the up flange at the back to the inside. Just drilled holes in the material in front of it and plug welded it.
Not sure this was the best fix but after welding in both corners it is very strong and looks good.
SC74
You got the hardest part done - removing the old crap and getting it ready for the new pan. Just take your time and use some screws to get it right and snugged down before welding.
Explorer
Raphine, Virginia
I don't where you got the pan, but I have read some recent posts about floor pans not quite right, so figured I'd add my two cents. I just replaced both sides that I bought from BGY and they both fit perfect.
ZuperDave
ZuperDave
Hanford, Ca
Thank you Dale Brisco Manufacturing.
"Quick Plug"-
They perform custom fabricating of steel product, I found out they actually manufacture the Full Throttle Custom lift kits, the do laser cutting and everthing. Bead Blasting and Powder Coating and Custom Fencing and Gates.
I took my new floor pan to work in hope I could find a brake to refold the tab. Jamie Brisco was able to unfold the factory fold and re-brake it to the correct position. It looks great, everything lines up know. The measurement was only 3/8" off. It's going to work perfectly. :Thumbsup:
Tommarrow I weld it in. :welding:
Pictures to follow..............................
I don't remember where I got the pan, I have had it for four years. ?
ZuperDave
ZuperDave
Hanford, Ca
I've been working too much,.....Did allot of welding this weekend. Everything is welded and now it is time to grind and prep.
I get this unsettling feeling when I think everything has been removed and out of the way when another piece has to be taken off to get more room or to get behind something. Today it was my fuse and relay box. I had a big hole behind it that needed to be filled. I filled so many holes that for a moment I almost filled some that I needed left open. It is amazing how many holes where in that tub, that where not in use anymore.
This is what the Fuel Tank Access Hatch is looking like, I figured that I'm not going to be using it very often, but it is there just in case I ever need to replace my in tank electric fuel pump or sending unit. I will coat it separately and use a Black silicone to seal it up.
Driverside floor pan all stitched in,...It is coming out very well. I purchased some body and seam sealer from Por15 also. I will fill the seams to smooth things out a bit before actually adding the Por 15 Flex Cote.
ZuperDave
ZuperDave
Hanford, Ca
Here is an update,....The prep work was extensive, but its finally done. Here are the pics of the prep work before the coating was applied.
First, after all the grinding and wire wheel work, I finally got to apply the Por15 Anti Rust Paint. This is to be used in all areas prone to rust. So I covered all the seams and some of the slightly rusted areas that I just didn't want to replace.
Now for the finish coat,...I used Por15's Black Cote followed by Por15's Flex Cote. The Flex Cote requires a primed surface and the Black Cote is good for bare metal. So after spraying the Black Cote throughout, I toped it with Flex Cote. It is not as think as a Rhino Liner, but its smooth. It didn't hide the imperfections like a Herculiner, but it's suppose to be tuff. I guess time will tell If I'm going to be happy with this product. I know one thing, the stir stick that I used to stir the Por15 Flex Cote, was stuck to the floor as if I had glue on it.
