If you're not keen on the idea of separating the pieces, you should be able to find a hub and rotor assembly fully assembled and ready to go even with new bearing races installed.
If you go that route, I would get new bearings too, since using old (or presumed old) bearings on new races would defeat the purpose of that whole "new" concept.;D
Is this Bronco new to you? If so, all the more reason to inspect and repack the bearings. Or completely replace them if it turns out to be necessary.
Most PO's don't know about bearing maintenance, so front wheel bearings tend to get ignored more often than you would think.
And speaking of bearings... If you don't know how old your rear wheel bearings are, keep in mind that by 100k miles or 40 years (whichever comes first!) it's time to start thinking about their replacement as well.
Unlike the fronts (which can last the life of the vehicle with proper maintenance) these are sealed and non-adjustable. They get replaced when "it's time" for them to go.
That interval varies greatly per vehicle and it's use, but in general I consider them ready to go at 100,000 miles. I've seen way too many fail by 115k, to 150k to ignore them.
And now, with at the very least 40 years on the old grease, if a bearing is original, it's "time" to go no matter how low the mileage supposedly is.
