I have spent days on this forum trying to determine if I could replace my kick panels without removing my door pillars. While I did find some statements that it is was possible, I was not able to find any specifics as to how it was done. I have a 1967 bronco. The rockers, inner rockers and door (A) pillars are in good shape, but the kick panel is not. I removed the outer rocker, hoping I could reinstall it. However the front of it is sandwiched between the door pillar. I guess my question is how do I remove the spot welds on the the front of the rocker without separating the door pillar? The body brace appears to be in the way to remove them from the backside. My second question would be how do you mount the outer rocker if you were to purchase a door pillar that is not in two pieces?
Thanks in advance for any advice. I am new to this so forgive me if this is a stupid question.
