Replcement Horns
jckkys
The OE horn is the single low tone. Mine filled with water so it's toast. To replace it I would like to as close as possible keep the original appearance of the optional duel horn. The single low tone just isn't loud enough to wake up a texter coming at me in my lane. The duel horns would have to include a high and a low tone and fit in the original location. So far I can only find the OE type single low tone.
73azbronco
Seriously, ebay, mid 80's Cadillac horn set. Sounds like a freight train.
904Bronco
San Martin, CA
Dual horn set from a 2000'ish Crown Vic. Easy to get to and plenty loud. Wrecking yard score for about $10
904Bronco
San Martin, CA
I have a Grand Marquis with the Crown Vic horns. They work well but look nothing like the OE Bronco duel horns. I found a thread where Paul came up with a photo of the originals. Here; https://classicbroncos.com/forums/showthread.php?t=298604&highlight=original+duel+horns
Well I moved the battery to the Drvrs side for the Explorer motor, Then the horn was in the way, and well as stated the Low side is weak. So the above fit under the battery tray since they are smaller. It was just a thought...
reamer
Hadley air horns, either under the hood or mounted on the roof:eek:
J
jckkys
Or maybe I could get some train air horns. Or more realistically, my problem would be easily solved with the optional duel horns. The factory did a poor job selecting a mounting location for the horn or horns. Mine was mounted with the bell pointed up so it filled with water. I'm not sure if it was planed, or if it was an assembly line worker who had a hang over. I found a pair by Dynacorn here;https://www.cjponyparts.com/dynacor...-note-chevrolet-gmc-truck-1955-1979/p/HORN6K/. I can bend the brackets like the OE brackets and orient the bell down and forward to both keep water out and project the sound forward. This is a restoration after all. Every other source only had OE type single low tone horns. The combination of a low 400hz and a high 500hz horns are very effective explaining why that's how it was done for many years.
904Bronco
San Martin, CA
Years ago I picked up a second horn from an 70's LTD in the wreaking yard. Took a portion of the harness and made a stock looking jumper wire. But now they laugh at you at the wreaking yards here when you ask about really old cars, nothing over 20 years old...
Got an old school yard by you, maybe that would be a good source?
J
jckkys
The good junk yards went away here in Tucson. They just crushed everything. It's a crime because the steel parts last for ever here. I don't know if it was the 2007 recession or Obamma's destructive cash for clunkers scam. I do have 2 OE horns off EBs that don't work but the brackets are clean and rust free. I may cut the spot welds and use them with the Dynacorn horns. That is if the Dynacorn brackets can't be bent like the OE brackets. The Dynacorns are oddly claimed to be replacements for Chevys too. I've got a quality crimper that will easily duplicate the OE duel horn harness. The whole harness is '77 so there is a horn relay.
