Restomod Air AC Unit install pics...
Madgyver
Bronco Madman
Sharing pics of my Haymaker-S AC install on the green77...
Wrightracing
Thanks for sharing. I have a 1972 body that I am widening and stretching to fit on an 1986 Chassis. I am looking to modify that area also for a Vintage Air Monster Cooler System. Which is one of their largest heating, AC and defrost system's. On top of that, I have to deal with coilover shock towers and a rollcage in the engine compartment and the cab. Plus I do want a stock size glove compartment.
So I can move things around, but some work is needed.
Thanks again for sharing, it helps me think about my plan for that area.
Nice work.
Sent from my SM-N960U using Tapatalk
phred
Earth
Mad, Great work as usual. Always amazed at how much work you can get done with those rusty trucks on the island.
grinnergetter
I just put in the fits "Bronco" version. The vents outlets running sideways rather than up like yours. An adventure for sure. I only have the heat operational but the motor sure sings kinda loud IMO.
Looking forward to your wiring, seems like the thing needs more than a few source 12v. IIRC. I got frustrated and moved on to something fun like getting my doors to shut properly.
Madgyver
Madgyver
Bronco Madman
I got this far for now... I used ARP oilpan flange head bolts to mount the cover.
Bitch'nBronco
Loose Cannon
Ringwood, NJ
That looks great, definitely going to save this idea for a few years down the road
Sent from my SM-G981V using Tapatalk
Wrightracing
Nice Job, did you use Nutserts or did you just screw into the sheet metal?
My new tool is a air powered nutsert gun. And I try to find a reason to use it when it make sense. It has made things come out more professional looking and easier to deal with.
Madgyver
Madgyver
Bronco Madman
I tack welded nuts on the receiving ends of the metal. You can see the 3 tack welded nuts in the upper right hand corner as these will be visible from the engine bay. I used ARP oil pan flange head bolts that I had laying around.
I do have the nutserts and install tool but they tend to leave about a 1/16" space in between the cover when it is bolted together. Good for other applications but not for what I am trying to achieve here. It needs to seal tightly, I may cut a gasket/rubber seal or just run a bead of RTV.
71 CA Bronco
Great idea. I like the removable side cover. Are you planning on making a removable top above the cowl. I did the raised cowl for my Vintage Air but kinda regret not making the top removable for better access. It worked but still a tight fit. I would imagine installing AC without raising the cowl is crazy tight.
Wrightracing
Ok, yes, the edge of the nutsert would cause it not to be flat, my thought would be to recess it on the panel or recess the hole on the cover just a thought and still do a rubber gasket. Just thinking out loud.
I have never been a big fan of welding nuts to sheet metal, even tack welding them, but I have done it in the past.
Still, nice work you are doing.
Rustytruck
Air Conditioning in Hawaii? Worried about global warming? Good for getting rid of humidity. make sure you have a good drain system.
steelefx4
Wish I had seen this a few weeks ago!!! Just finished a Vapir-2 install, would have liked to fit the Haymaker for the 110 degree summers.
ctay
Is the Haymaker significantly more powerful than the Vapir-2?
steelefx4
I think they run the same fan, but evap is larger which equates to more cooling...how much more? Unknowable.
