rae61
- Jul 13, 2007
- 171
Installed according to instructions and system works fine with engine not running. However, when the engine is running the sound cuts in and out at the speaker. This happens for the AM&FM and also the Bluetooth from iPad and iPhone. I'm using the Retrosound in dash D52 speaker. Retrosound tech guy was very nice and suggested that I run constant power from the battery, and run ignition from battery using a relay. A ground from the battery was run to the dash and the radio grounded to the dash.
The changes the tech guy suggested did not change or fix the problem, does anyone have any ideas?
Thanks!
Thanks!
