Yes very worn stock bushingsAre you using stock bushings currently?
No I don't.Do you know what your current caster is?
Sorry, I click the corners of uploaded photos and drag them to a clickable thumbnail.Nevermind. It just took a bit for things to normalize on my computer, and now I can click on the images to enlarge them.
Looks like a high-pinion diff with the pinion pointed too high. So yes, you need C-bushings, but not reversed. Since they are designed to lower the pinion angle, installing them the normal way will get you more of what you need.
What about lift? If it's a tall lift, then you'll also need to watch your upper double-cardan jointed angle.
By the way, is the vehicle fully assembled at this point? Or still lacking certain things? Looks like an awful tall lift from here.
Maybe they weren’t both actually 7° bushings.I had two sets of 7° bushings and oddly they are very different
The Black one has more lip on the lover inside.
They turn the same way. I guess the blue one is trash.
I will be more direct than @DirtDonk The answer is YES. To use your wording, the pinion will seek down under load. Or, if it is easier to imagine, the pinion will seek up as the suspension is unloaded.This is a 3.5 inch springs and yes, Duffs long arms.
And yes a high pinion D44 full width axles
So @DirtDonk I might have been thinking this wrong. Under load the front pinion will seek down?
Your analysis is inadequate. The flexibility and umconstrained angle of the “fold” will impact that measurement. If you want to compare performance, you must constrain the urethane bushing as the c-cap will.Thank you all for the great advice. Things are looking much better after just lowering the front.
I will use you advice @jamesroney .
I did take some additional photos of the C bushings
They are both 7° but bought from different vendors. I don't think it matters who sold who.
Butt we ought to be aware of this. I have no idea what this means other than they will not work the same
I will keep you updated on the progress here.
Click the photos to enlarge
Top view. Facing the same way
Front bottom facing up and a leveler. Difference
Rear bottom leveler. Equal
For the rear:But why do you talk about 6.5 + 3.5 = 10 inches long in to separate measures? Why not just 10 inches?
